is this thing for real,or B.S.?!!
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
it does increase gas mileage by killing your power/airflow. about 1 - 2 % increase in gas mileagle. - the denver post :p
T701jz
3M ENGINEER - R.&.D
Jul 23, 2005
657
Santa Clarita Ca.
Where did you get your info? Toyota never gave up. If you’re talking about the MKIII, the end result of that is the MKIV.Tons of engineering works and money. No one in the manufacturing industry moves backward to correct the problems. Engineering moves forward for a better result to the next generation. Engineering learn their mistake always from the previous end result and you go forward from there. It takes tons of research, credibility, and massive test before any one agrees to put their name behind others product. Now, do you think they be willing to risk their reputation? It takes money and engineering mind to improve/modified your vehicle to your expectation and if you’re one of the guys that put bigger turbos (HP), try to know better then the engineer, and expect the car to hold up more then to what it’s capable of. Then, I can’t expect you to understand what I just posted here.
Yes, I'm an Engineer and to be precise I'm the factory operation team leader for engineering and maintenance at 3M pharmaceutical.
