wait.... IHI... how did u get it to 8? different computer? You coudlent get an aftermarket tac working either!!!??
me said:FYI My dad and I have rev'd to 8400 on stock valvetrain with no float, no spit shims, etc. Why? well, the tach didn't work with AEM yet and we figured we'd shift when the power let out. Oddly enough, with a T-78 the power didn't let out for quite some time. Our valve springs are quite beefy and it's big cams that spit shims, not revs.
IHI-RHC7 said:JJ, Fuel cut is a function of airflow vs RPM to determine an ovreboost condition. Spark cut kicks in at any load at around 6750 in pre 89 cars. In post 89 it is at 6250 or so and an 89 could go either way depending on the motor mounts, crank, etc. (not that they have anything to do with rev limit, but they indicate which era the vehicle is.
jetjock said:For those electronically inclined the ecu uses an 8051 MPU. It's an old Intel 8 bit processor with internal eprom. The code is standard 8051 assembly language and can be read using any 8051 emulator or prom programmer. Someone said it was encypted but I didn't find that to be the case. Actually, I could be wrong but I know of no way to encrypt 8051 assembly langauge and still use it in that device.
