Is the Fuel Pressure-Up VSV needed in my setup?
MarkIII4Me
Project OVERKILL!!!
Apr 10, 2005
1,250
Charleston, SC
I'm in the final stages of completing my ride and I recently discovered that one of the "mystery plugs" in my bay belongs to the Fuel Pressure-Up VSV. It's simple enough to install, but I have no idea what I did with the thing. I'm sure it's in one of my many boxes, but I don't want to go on a wild goose-chase finding something I may not even need; or may not even function properly in my setup.
Not sure if any of this info is relevant but I'm running a JDM ECU, HKS VPC, no EGR, Aeromotive AFPR, Denso pump and 550cc injectors. FFIM is provisioned for the CSI, bypassed the FPD on the rail.
Does the Fuel Pressure-Up VSV function properly in conjunction with a AFPR? Did JDM Supras run the Fuel Pressure-Up VSV? Will leaving the plug disconnected produce an error code?
Overall, should I install the VSV (once found) or omit the damn thing entirely?
I understand what it does, so if it'll work with my setup then I'll more than likely install it.
MarkIII4Me
Project OVERKILL!!!
Apr 10, 2005
1,250
Charleston, SC
It is my understanding that the Fuel Pressure-Up VSV redirects the vacuum source from the intake manifold to atmosphere during startups and keeps it open for around a minute before directing the pressure source back to the intake manifold. How will this affect the fuel pressure if I'm running an AFPR and the J-Tube is removed?
What I said but I believe it uses a temp signal from the ECU to decide when it's active ie: hot starts.
Not sure if I understand your question, it will remove the vacc signal from the backside of the AFPR giving a higher cranking fuel pressure, our engines don't get a "Prime" shot when you switch the Ign on they wait for a ref/sync event before the pump becomes active.
MarkIII4Me
Project OVERKILL!!!
Apr 10, 2005
1,250
Charleston, SC
Sounds about right. I wasn't aware that the ECU uses a temp signal to activate the vsv. So regardless of anyones setup, (short of running standalone), the Fuel Pressure-Up VSV should function correctly without affecting anything else? I mean, I kept the CSI for cold starts, might as well keep the vsv for hot ones :)
