IJ. said:NGK 6's from memory and .028".
Hmmm...NGK's better than the Autolites?
these the part numbers for the NGK coppers?jdub said:Just looked the NGK's up on their site...BCPR6ES is the stock plug w/ std heat range. NGK is backwards on the heat range...meaning BCPR7ES is one step cooler.
Here's the tech info from NKG:
http://www.ngksparkplugs.com/techinfo/spark_plugs/techtips.asp?nav=31000&country=
Still trying to figure out the Autolites....
SupraDreamPDR said:these the part numbers for the NGK coppers?
appreciate it. now i know what to do if i start to miss at higher RPMs.jdub said:This should answer your question...
http://www.ngksparkplugs.com/products/cars_trucks_suvs/standard.asp?nav=11100&country=US
