I know i probably haven't been searching long enough, but i haven't been able to find it. I am wondering what trouble code will come on while driving and then go off without leaving a code stored? I believe a long time ago I read that a tps code will come and go?! When the light comes on I do loose power it doesnt matter if I am under boost or not. I have ohmed out the tps and it does check good. I am running the maf off of the lexus both housing and electronics with 550 injectors and a .57 trim just rebuilt from driftmotion! Timing is all set. I am running a little lean at 12.3 under 3/4 throttle too scared to go any more, and sitting at 14.5 at idle. I havent driven it more than half a mile at a time, and havent gone wot yet either. I am saving for a maftpro for tuning. I have read somewhere that the lexus electronics can make it run lean, and others have said it doesnt matter! so my other thought was a lean misfire/knock but I thought that if the ecu saw that it would store the code? any suggestions would be muchly appreciated! and sorry for the not so clear wall of text!
Thanks Dustin
Thanks Dustin
