intercooler spray
wingman
sucka got blammed!
Sep 11, 2005
427
Phoenix, AZ
I'm not sure the advantages of placement methods, but N2O can be sprayed either in front of, or into it. CO2 should only be sprayed in front of it, and methanol I think you could get away with spraying both places as well...but I might be worried about it pooling in the bottom of your IC.
supra90turbo
shaeff is FTMFW!
32
MA, 01440
lmao Y13... we did that with my buddy's old Subaru RX-Turbo, took the hatch sprayer, and aimed it wicked high. Pissed off some churchy kid who wanted to fight... it was too funny, we kept telling him that god wouldn't like that, god wouldn't like his attitude, god wouldn't like his tone... He just left
Spray your windshield if someones tailgating you on the highway. They get quite a mist.
I had a motorcycle that wouldn't stay the hell off my bumper no matter where I went, so I started washing my windshield, and yeah he passed me.
s383: spray directly onto the front of it. get a good coverage over it, but overshoot a bit, compensating for any air resistance.
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
people usually run a methanol shot right into the intake, i think. when i was reading up on it, it sounded like they'd spray it into the intake pipe right before the throttle body. anyone know the certain placement of this?
pimptrizkit
thread killer
Dec 22, 2005
1,572
vancouver Wa
i was pretty sure that nos is not flamable, and the reason it add's horse power is because the removing of the heat, causes the air to condense, a denser air charge and more gas and air enter the cylinders. like super charging but at a push of a button..
tookwik4u89
Red T-shirt
Apr 6, 2005
2,008
Rockford, IL
Nitrous Oxide by itself is non-flammable. However, the oxygen present in nitrous oxide causes combustion of fuel to take place more rapidly. Just like the Oxygen does with a torch. Way hotter than acetelyne alone.
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
we have winner with out going mega tecy :naughty:
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
y would someone spray NO2 into the front of the IC, when CO2 is so much cheaper, and you cna get it filled at any sports authority and paintball place
wingman
sucka got blammed!
Sep 11, 2005
427
Phoenix, AZ
not to mention a CO2 tank will run you $25 for a small bottle that can be anodized to match your car for another $20. Find a 12V 2 way air piloted solenoid, rig it up to a switch in the cabin and connect your lines to it...use a regulator before the solenoid to keep from blowing something up, regulate it down to about 250psi, send it through the noid and into your sprayer.
total cost should be about $150 without the IC ring...at least with the parts I plan on using and also with 1/8NPT braided stainless line.
tekdeus
Pronounced Tek-DAY-us
Jan 23, 2006
2,115
Vancouver Canada
www.bitrontech.com
Where are you going to get these parts? Pricing seems very good for a worthwhile performance mod
NashMan
Aug 5, 2005
4,940
17
Victoria BC
man i don't know about you guy's but i am going to run silly gas right on my ic will i use it all the time no so a bottle will last some time caise only use it on really hot dasy at the track one 2 secound shot is all you need think of it as purge
in fact i going to be runing no2 so my ic spray will be rig up as my purge
wingman
sucka got blammed!
Sep 11, 2005
427
Phoenix, AZ
I have an account with SMC for solenoids and stuff, but regular 2-way solenoid valves aren't hard to come by. Far as the bottle, you can use a 20oz paintball tank, or a small 15lb one, hook it up to a regulator that outputs via. a 1/8NPT line, run a few feet of line to the solenoid which is switched in the cabin through any 12V line, then from that to your IC sprayer.
I used to be pretty heavy into paintball, braided line used for that isn't near as expensive as the braided line and AN fittings commonly used on cars...the most expensive parts will be the solenoid, regulator, and the sprayer ring.
