intercooler spray
Clied
Wangan Supra
Jun 8, 2006
367
NorCal
would it be possible to rerout the headlight washers to spray water on the IC i want to replace my front nose piece with one that has no headlight washers but i hate to have a button in my car that does nothing so i thought this wouldd be kind of neat
Insidious Surmiser
Formerly 89jdm7m
May 12, 2006
2,172
Oceanfront
yes.... already done :biglaugh: just wish the water res. was bigger so i could put ice in it or something :-/
edit: oOo headlight washers... i used my windshield washers
s383mmber1
3,614
Somers New York
This is interesting, i think i would rather use the windsheild washers than headlight washers, they seem to have some more power.
Pics anyone?
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
This sounds very interesting, a cheap way to make the intercooler more efficient and squeeze some extra power out of the supra. What do you all think, 10-20 whp gain by doing either the headlight sprayers or windsheild sprayers... Or how about this, BOTH windsheild and headlight sprayers?
aye mate
Hiatus over.
Maryland
I'm gonna do this until I get a co2 sprayer. I would probably just use it at the track before and after runs to try and keep intake temps down.
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
guys your ic are not tomato plats water em down ant really going to do didlly
in less you had setup like a gt4 mr2 ect then it help some
the only way to go is a nos or co2
tookwik4u89
Red T-shirt
Apr 6, 2005
2,008
Rockford, IL
Nos, really, I dont have the nuts to spray that shit in the engine compt. That's scary. I'd go co2. Washer solvent is flammable also, but has a much higher flashpoint.
NashMan
Aug 5, 2005
4,940
17
Victoria BC
no2 is fine you need alot to do alot as in if some were to go into you intake witch most likly will not happen and if so not eghouhg to do damge in any way in less your filter is close to were you are foggin it
co2 on the other hand is even wores take up much needed fresh air
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
^yup, just don't spray at the track! Problem solved.
Edit: Just a FYI, I run Meth injection.. windshield washer fluid is 50% water 50% methanol, this helps keep my EGT's, detonation, and air intake temps down. I love it.. Its a similar idea. It is also 20% of my fuel at WOT.
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
aren't nitrous oxide and nitrogen different? a system set up to spray nitrogen would substantially cool the IC or the intake charge (IC) without any danger of igniting, i think. i didn't think nitrogen was flammable in itself, but maybe im wrong.
wingman
sucka got blammed!
Sep 11, 2005
427
Phoenix, AZ
i'm going to run a CO2 sprayer on mine, yes it displaces O2 but if you move your car 10ft forward your going to be back in regular air but with a freaking cold intercooler. Why else would people blast thier IC's with CO2 fire extinguishers? Water spray works too...just remember like everyone said to keep it off the track.
oh, and N2O is an oxidizer...it won't just "blow up", long as you don't have a fire under your engine bay you should be alright if that's what your spraying.
