intalled custom fuel rail and dual walbros
yaitsme
Beach Bum
Mar 2, 2006
245
Cheatham County, TN
I opted for the A1000 as well ... whatever happens in the future, I don't want to have to re-visit the fuel system.
Curious to see this setup, Q.S. - definately need some more (better) pics !!
Dec 3, 2003
6,653
Canada
mustangman05 said:
how much HP will the a1000 allow or is the sky the limit??
700 is about he max. Also listed on Aeromotives website.
I had the A1000 but upgraded to the Eliminator.
Nice job Quick! Keep us updated and more pics.
Duane
tookwik4u89
Red T-shirt
Apr 6, 2005
2,008
Rockford, IL
I run the dual walbros, it is a PITFA getting them in the tank right, but works well. I read alot on the forums complaints about the noise, but I cant even hear mine.
QWIKSTRIKE
475rwhp459torq an climbin
Apr 3, 2005
1,172
Some where out there
tookwik4u89[B said:
]I run the dual walbros, it is a PITFA getting them in the tank right, but works well. I read alot on the forums complaints about the noise, but I cant even hear mine[/B].
Not hard if you take inner lip out. We cut in different places fold the cut tabs up and hit it out with a sharp chisel and hammer.
joliroger4
Flying Dutchman Pilot
Apr 4, 2005
264
New Jersey
www.geocities.com
Nice, I just redid the fuel system on the grey car with dual walbros. What's custom on the rail? I tapped my rail for a new return so I could have a dual feed and keep the csi. Even with 720s and the vpc you would think my car had 440s and a stock afm on it, it runs identical to stock.
lagged
1991 1JZ
new rochelle
awesome
tookwik4u89
Red T-shirt
Apr 6, 2005
2,008
Rockford, IL
I used thick zipties, several around each pump, then zip tied them together, it spaced them apart about 1/8". I run -8 from the tank and split to 2 -6 feeds to both ends of the rail where dampener and fpr were at...then I drilled/tapped between 3&4 for the return to afpr so the pressures would be even.
