screaminglemon said:um.. 16.4 inches!?!? maybe for an N/A. but i thought shorter runners were desirable for forced induction.
It was just an examlpe!!!
Did it look like this..the lower is from a 7M.prsrcokr said:Did anyone notice the mkIV spread in the latest issue if modified? It had a manifold setup very similiar to the stock 7m turbo. Looks like maybe they modified a N/A manifold but the guy was making some big numbers with the setup. I'm curious why he didn't use a front facing version from the turbo model.
Brian W-88T
It's ok Duane, thanks for looking out. I think the pictures were taken before the I sold the tbupgradedsupra said:Good guy in posting pics Ron ... > I simply suggest you not post any really DETAILED pics as you may get the manifold copied. You know me bud, as I am trying to look out for you.![]()
The manifold pics you had before should be posted. I may have a few of those instead.
Also > Take that TB off that manifold as it is mine![]()
Check out my sig
Duane
Check out my sig
Duane
screaminglemon said:im interested in that short runner, vielside type looking one. what needs to be relocated to run that? i dont mind moving the battery or alternator but i must keep AC.
jt2ma71 said:I want to make sure it's OK to post prices here or I'd rather have you guys send me a PM.Thanks! Ron
DEFIANT 7M said:Did it look like this..the lower is from a 7M.
http://www.villagephotos.com/pubbrowse.asp?folder_id=1267173
Also that manifold has ACIS http://www.geocities.com/mwsupra2003/acis.html link from Jong's thread on SF.
