when I was removing the head, it looked like the cam gear on the exhaust cam is a tooth off from matching the factory mark on the gear to the factory mark on the top of the plate that's behind the gear when the first piston is at TDC. The gear needs to be turned counter clockwise to match. I read the haynes manual and it says to put it back together how you found it, but the timing belt was changed by the previous owner, so I think there may have been a mistake. What do you guys think I should do when I put it back together?
