installing catch-can.
malloynx
NC
i just recieved my TRD catchcan. i'm pretty sure i know how it goes; but i just want to double check. there are 2 ports on the top. 1 to the valve covers and the other to the pre-turbo vacuum.. correct?
Slow66
I think with my dipstick
Apr 3, 2005
1,457
Newington, CT
Sounds good to me, unless you want to modify it for a 3rd port, so that you can run off both valve covers individually to the catch can, and then use the 3rd to the pre-turbo.
Either way....
7M-GTE
ROCK$T@R
Apr 2, 2005
535
KC
yeah use a Y connector for valve covers and then with mine the other hose will go to my intake tube on the turbo...
whiplash
73
Ottawa, ON
malloynx said:
well i modified the stock PCV metal piece. i can run off both valve covers with 1 hose. :)
Sweet, sounds good. Also, the stock 7mge PCV hose works well, it's like a "U" pipe between the two covers, with a port in the U to send off to the can.
7M-GTE
ROCK$T@R
Apr 2, 2005
535
KC
anyone know where to place them if you have abs... I'm having problems finding where to place mine...
Justin727
T-virus infected
best pic i got of mine for now. photobucket is down and i cant get to my better picture. hope this helps. Its an picture from last year...
7M-GTE
ROCK$T@R
Apr 2, 2005
535
KC
schaef so did you just wrap it with some sort of clamp... and strap it to something? do you have any closer pics?
shaeff
Kurt is FTMFW x2!!!!
11
Around
Justin727 said:
Sorry to go off topic but shaeff you are going to hit up the rust in the engine bay too correct?
yes, all the rust will eventually be taken care of. exterior first, as that's the worst of it. the underhood stuff is surface rust, and can easily be fixed.
and i have mine strapped to the brake booster.
-shaeff
