I've been asked many and seen the question asked about installing a catch can on the 7mgte. Here's a quick rundown of how I did it.
Ok. Here are a few random pics I took today and an old full shot of my motor before some changes. You can still see the setup, though. It's been on for about 2yrs now.
I've numbered some things to help explain. Sorry if the numbers are a bit small. They are in red, though.
1 - catch can (Mine has a silica filter to help trap oil, a drain on the bottom or I can unscrew the cylinder from the top and clean/dump. You want something easy to clean out. I never use the drain, I remove the bottome section because I like to clean it completely. I know many "catch cans" don't have this option, however. You don't have to have a filter media. I think it helps. If you buy one without filter media and it can be opened, just buy some **metal sponge scrubbers(see next pic)** from walmart of a grocery store and stuff them in the 'intake' or filter side of the catch. As you'll see in the pics, I've mounted mine in a location that not only has plenty of room, but was located in a good location for how I wanted to run it, but most importantly, it's located in a cooler location. If you do not mount your catch in a cool location, much of the oil will not condense and will pass right though!
**Like this or similar:**
2 - two hoses coming from cam covers and then tee'd into one. Some catches have two intake hose nipples, mine does not.
3 - return pipe (modified = pipes cut off from bottom and then braised shut.) I wanted to keep a stock looks and not have all this extra rubber hose running everywhere like many people do. This looks clean and stock and many don't even realize what I've done until I show them. (I think it looks obvious, but if you don't know...)
4 - return hose. This runs from the catch to the modified pipe which runs to the original, stock location located on the intake accordian hose. ***Addition/Edit*** Throttle body port should be teed in to hose #4. It does not currently show it in the pics as I haven't had time to take any new ones. Pics will changed later.
I need to fab up a little bracket for the catch (Right now, there's just the zip tie - which does work fine for now) and rerun the return hose (4) in a more discreet way.
Here are the pics, now. I wish the pics and process would have been better documented, but I hadn't originally planned on doing a writeup. Let me know if you have any questions.
Christian
Christian
