well now that i see it, then jumping the ignition wire with the battery should make it attempt to crank.
suprahooked said:Try charging your battery or jumping it ,Is the starter bolted in tight and nothing stopping it from being tight to the bellhousing?
CryoSlash said:well now that i see it, then jumping the ignition wire with the battery should make it attempt to crank.
jetjock said:What is the voltage across the battery when this happens? If you're supplying adequate power and control to the starter (and it sounds like you are) then it has to be the starter itself. A lesson in always testing new parts prior to installing them.
Better yet make them test it went you get it so you dont get another bad one.:biglaugh:Sawbladz said:You called it. I will do this from now on. I hope to have the new starter by Tuesday and will report back then if a new starter fixed the problem.
suprahooked said:Better yet make them test it went you get it so you dont get another bad one.:biglaugh:
Tools are a mans best friend:icon_razzNick M said:It ceratainly isn't easy without the correct tools.
So i take it that you had a bad starter.Sawbladz said:Today I pulled the starter and will be leaving for Parts Source soon. What a difference experience makes. I got it off and in my hand in under 1.5 hrs. Will update later if I get it installed and running. **crosses fingers**
UPDATE: New starter in, some wiring repaired, car now runs. I finally got to take it for a nice long run.
