how do you guys go about removing and installing the injectors? do you remove the intake mani? wiring harness? poop? im about to try my 550s but i dont know where to start soooo if i could get some guidence that would be great.
tsuper92 said:i've read you can get the rail out without pulling the mani.i guess if you take the tb off and some other part's it give's you more room.i ended up pulling the intake because i was installing top feed rail and the resistor harness with the clip's for the injector's.wish i could give you a better answer,but i haven't seen any step by step direction's
suprastanger507mgte said:Yes, I did remove my TB,the ISC and the throttle linkage and the crossover tube.
Removed the fuel line from the FPR and it was real easy to get to after that. It really helps if you have the Racheting wrench since its low profile and the six bolts are eay to get to.
Despite his user name, Moe has a 1jz too. Hint in his sig.itr206 said:Dude, he has a 1JZ. totally diff engine.
Johnny. I did mine without removing the manifold. It wasnt the easiest thing in the world, but it worked.
I removed the Throttle body bolts so I could move it around and removed the ISC if I remembered correctly too.
Unbolted the lines for the rail and just popped out the rail bolts and pulled the rail off.
The trick is once the injectors are out of the manifold is to try and rotate the rail around to fish it out.
Not easy, but can be done.
hey man, you don't gotta lie to kick it.suprastanger507mgte said:I know that he has a 1jz, so do I .
No thread jacking please. Keep on topic lololol:biglaugh: :biglaugh:OneJoeZee said:hey man, you don't gotta lie to kick it.
You'll get yourself a 1J someday, ok?
itr206 said:I know you do, but you posted instructions for a 7M.
Read what you wrote and you will see why I posted that
itr206 said:Where is this throttle linkage and crossover tube you mention on a 1JZ?
