Injector Ohms, which multimeter setting?
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
As the title states, I'm trying to figure out the resistance of the injectors. I was wondering if anyone knew what setting I should use for testing. It has options for rx1, rx10, and rx100. The different settings all give me different results. Does anyone know which I should use?
jetjock
creepy-ass cracka
9,439
In the case of injectors (especially turbo injectors) you're measuring not many turns of a coil of wire. That's going to be only a few ohms. Use the lowest range the meter has. X1. Iirc GTE injectors should be around 4 ohms with the external resistor pack being used to limit their current.
