injector keeps pumping gas into cylinder
johnverheij
shoarmateam member
Nov 21, 2006
64
netherlands
bigaaron said:
So...... what was the problem? I have seen a bunch of ecu's that work fine for a while, then suddenly keep injectors open, then 10 minutes later work fine again.
well i think one of the stock injectors is not working properly
MOON
34
calgary alberta
sounds like a short to that injector wire. test them, i had a simular problem at work, and sure enuff, injector wire was shorted and kept the injecter wide open. if you can. unplug it ,itll run rough ,but see if the smoke goes away..
