injectctors wont pop
So your not getting fuel?
Jump fp and b in the diag box by the battery and check to make sure the fuel pump works.
mkiiichip
1,434
WI
Explain what steps you took, that showed the injectors do not "pop". Are they getting signal but not opening?
Are you having a no start problem, a dead cylinder. a little more info is needed.
figgie
Twin Cities, Minnesot-ah
what the????
Pop open? CEL flashes constantly when in diag.
CEL indicates no issue.
What the hell is pop open??
English!!!!!!
edit: movingthis to genral unil OP lears how to ask a queston in a language that everyone here can understand. So far three replies, and all the same thing...
Each ones post begins with a question asking for clarification.....
YUNGPIE
17
BAKERSFIELD CALI
Injectors wont open .
And i jump the fuel pump, and it does turn on
there is fire to the plugs
ther is power to the injectors i checked with an amp testor, but i grounded one of the wires and you can hear it click
and squirt, because i tried it with the fuel pump on direct, crankd it and nothing.
Whats up guys can you help me out or not enough in? Hit me up.
8,898
Power is supplied constantly to the injectors when EFI circuit is running. The ECM grounds them in groups. Just a hunch. I don't think you have 6 bad injectors and the computer doesn't work. Then again...
Failure14
276
Ohio
hvyman;1535164 said:
Injector clips 1 white, 2 brown, 3 white, 4 brown, 5 white, 6 brown.
Do what this guy said, if you do, then your injectors are not wired wrong and you can rule that out.
Also sometimes(But usually there worn out) they will still have the number on the clip for which injector.
YUNGPIE;1535292 said:
If there is a bad computer is there a way to tell?
The ECU's in these cars almost never go out, matter of fact i haven't even ever heard
of one going bad and im sure someone else will back me up on this.
Your ECU is fine.
As the guy said earlier go here, and study this like the bible.
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/default.aspx
You're obviously not listening to anything anyone is saying, so untill you start
answering questions, quit posting.
A picture would be a bit helpful also...
JesseH
1,153
YUNGPIE
17
BAKERSFIELD CALI
Were do the injector plugs ground out? Bc i chased the yellow,red,black to the resistor and then fallowed the black and orange wire all the way to under my dash and i have no clue were else it goes !!!!
