Info and write up on oil and water lines...
Reign_Maker
Has cheezberger
Aug 31, 2005
5,767
Florida
I guess I'll stick with 4... I've gout about 15 feet of 4AN high pressure line, so Im gunna use that... I was thinking about using it for my fuel, lol... kidding kidding...
Reign_Maker
Has cheezberger
Aug 31, 2005
5,767
Florida
Banjo bolt... Jeez, I keep calling them Eye Bolts...
So anyone have any idea what fuel rail fittings work? Feed and return? :)
Reign_Maker
Has cheezberger
Aug 31, 2005
5,767
Florida
Fantastic! Thank you! So instead of a -6 adapter for the feed, I need a -8... Thanks!
Only two left, the water inlet/outlet on the turbo... :) I think they might be 1/2" NPT or pipe...
Fitting sizes...
Oil feed from block: M12 X 1.25 (-4AN)
Water feed from neck: 9919DFG (Earl's) Top of water neck is 1/4 NPT (may have to tap it)
Water return to neck: M14 X 1.5 (-6AN)
Turbo inlet/outlet water: 981666 (Earl's?)
Fuel rail inlet: M14 X 1.5 (-8AN or -6AN)
Fuel rail return: M12 X 1.25 (-6AN)
bwest
Drafting, not tailgating
May 18, 2005
502
HippieTown, CA
Jake - could we condense and then sticky this info? or how about moving it to the FAQ section (so we can continually add different sizes of fittings on the motor).
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
I second... very handy info in this thread.
