increase the heat
doom26464
Research...research
Saskatoon SK, Canada
I put some cardboard infront of the rad and it helped a bit. The car blows really hot once it has had a good 20-15 mintues of driving now so its not horrible bad now I think blocking all the cold air to the rad with the cardboard helped a bit.
shaeff
Kurt is FTMFW x2!!!!
11
Around
x87SUPRA87x said:
How do you get air out of your heatercore? Mine has been makeing that bubbleing sound for a while now and my heat is not working very well :1zhelp:
park on a hill, take the radiator cap off, rev the motor to 2k rpm, with the heater on full blast.
that should purge the air from the system.
dont burn yourself!
-shaeff
bwest
Drafting, not tailgating
May 18, 2005
502
HippieTown, CA
two things to try:
install a check valve in the heater hose running from the head to the heater to create a low pressure area for air to escape when filling up w/ coolant.
install a good thermostat. I'm using a high-flow Ford motorsport thermostat from a 4.6. The design is a little different than the standard wax bulb of most thermostats. also (by design) it allows more water to pass under high pressure (think of it more like a plate bypass. iirc, stewart makes a t-stat like it).
and yes, they are the same size (diam).
