i'm not too sure...
tmaxx31190
Got Insulin?
Nov 22, 2009
45
Walled Lake, MI
ok, the trouble code that is showing up is "51". from what i could find out 51 means eaither the airconditioner switch or the neutral start switch. i have the R154 tranny so i don't have to worry about a neutral switch. but could an A/C switch really be causing my problem??
---------- Post added at 03:55 PM ---------- Previous post was at 03:52 PM ----------
ben1984j;1536246 said:
^^ True...OP, you said the "timing marks were dead on"...guessing you mean cam + crank timing...but did you check the position of the CPS when #1 piston is at TDC? This write-up might be helpful: http://www.supramania.com/forums/showthread.php?38775-How-To-basic-timing-instructions-CPS-alignment
ok i'll check this out, thanks
ben1984j
159
Ft. Collins, CO
If the A/C button is pressed while you're checking codes, then yeah, it will set a code 51. Same thing if the throttle isn't closed (your foot is on the gas pedal or it's somehow stuck partway open). Other than that, a code 51 points to the TPS or TPS wiring.
tmaxx31190
Got Insulin?
Nov 22, 2009
45
Walled Lake, MI
ok, the trouble code i'm getting now is the "camshaft sensor signal" i did a compression test and i'm actually getting compression. what do i do?!
