All i found was a dead-end thread and, this quote from the you know you own a N/A when thread ; "you know you're a N/A owner when your friends notice a bit of a whine and you have to tell them its not a turbo spooling....but you wish it was." Is this common?
I notice a whine coming from my engine bay under acceleration, namely under a heavier load while accelerating. It's faint when i accelerate slower. The tone of the whine goes up with RPM, and it is LOAD dependent. If i accelerate at a steady rate and then push it harder the noise gets louder based on throttle input. Let off while going the same speed and the whine disappears. I have heard a little differential whine too i think, but i can definitely tell this is coming from in front of me.
I mentioned my problem before in another related thread and a replied possible problem was the steering pump, but pushing the gas pedal harder won't effect that...this is RPM and load dependent...
I also sometimes cruise in 5th gear around 40 mph, and the other day i pushed the pedal down hard to see how my car would pull in 5th going that slow. (yay torque) I heard the whine still, but now I also heard a kind of hiss-like rushing. It's not the gushing waterfall sound, it almost sounds like air. I'm not sure how to describe it. I was stressing the engine doing that, but the sound...confused me.
Any ideas? :1zhelp:
Any ideas? :1zhelp:
