Yeah, but i need to find one hows preety simular to the supra H-pattern
I have no ideea wich one i shoud take
the point is its no diffrent then the triptronic only this version doesnt shift one when your in triptronic mode. it just a triptronic 2.0 nothing more3p141592654 said:SMG can be full manual, or full auto. I don't see your point. The only lazy part about it is the clutch which is hydraulically actuated for you with various selectable programs of engagement speed.
3p141592654 said:The SMG stands for sequential *manual* gearbox. It is not tiptronic at all. You are completely ignorant of what SMG is. Its a manual gearbox with an electro-hydraulically actuated clutch and shift forks.
Tiptronic is a conventional automatic with a torque converter and planetary gear set. It is nothing more than an automatic with manually selectable shift points, not the same at all.
If you don't understand, go test drive an M3 and open your eyes.
quote from the link I provided:
"It's not an automatic, and its not a manual. It's a sort of mix between the two. There's no torque convertor ( like a manual ), yet the driver can opt to have the onboard computers change gears for him ( like an automatic ). Oh, and there's no need for a clutch -- SMG-II does it all itself via hydraulics.
OK. So picture a manual, but without a clutch pedal. Instead of the conventional H-pattern, SMG-II gives drivers something different. Drivers can still opt to row their own gears ( hitting the rev limiter just like a normal manual ), but changing gears happens in the blink of an eye by pulling back or forward on the "shifter". 80milliseconds. No human could possibly change that fast. Oh, and if you have to downshift, you'll even get a little throttle blip as SMG-II matches revs. Heel-toe driving gone, perfect shifts every time. "
oh i know i love all the german cars. i just see it as another triptronic only on the other side of the scale.3p141592654 said:Munk, I edited my post to tone it down... got a bit carried away, sorry about that. If you can, find an M3 with SMG and try it out. Definitely not like anything you will have driven before.
Breth said:So i heard the Trans from the RX-7 shoud have a very simular H-pattern like the one from the supra!
But i dont know at wich position the reverse-gear is. It shoud by like the one we have got.
So anybody got a rx7 (twinturbo)here in the forum? And can answer my question?
Regards Breth
supra90turbo said:Yes, please do.
I wish I could waste $1800 on a shifter...
