igniter plugs?
reincaster
68
Guam
So after dropping in the engine from my 88T into my 90T, I came across a few things I'm not sure about:
Are the igniter plugs the same for 86-88 and 89+? I know one is grey and one set is gree, green being the early models, but before I go digging in my 40ft storage container for the older one, will it work or will I have to cut and crimp?
Are the plugs that go to the starter different as well? Now that the starter is in, it's a bit of a pait to look at it head on. I know I should have checked, but I was in a bit of a hurry to get the engine in so I could return the stand to a buddy. I also heard that the 89+ starters have threaded holes, as opposed to the nut and bolt deal I'm used to.
thanks in advance!
Ignter plugs are the same just the later ones had gray plugs.
Starter plugs are the same.
Newer starters (i think 90+) have the threaded holes so only bolt is needed
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
the starter is hell to get at any way you slice it...unless of course you remove the upper intake manifold. For a $15 dollar gasket, it is almost worth removing it.
I also support the above post.
