Ok I have a 1988 toyota supra 7mgte I just put a Titan Motor Sports 1.4mm MHG on it. The car use to have idleing issues before it warmed up. Once it reached operating temp it would idle just fine. Now it idles very rough once it hits operating temp and not at all when its cool. It usually tries to idle around 400 rpm which I know is low. The first test I tried was removing the pcv from the throttle body. The car would stay runing but only if you held your foot on the gas. Should it die all together? If it should die altogether that means I have an outside air source entering my intake somewhere correct? Does Anyone have any other suggestions on what I should try replacing first or maybe other tests I could perform. I have been using the search function to try to help myself but I havnt found anything thats worked yet.
Side Note: I had to reuse my old upper intake gasket because I fubar the stock one and I havnt had the funds to replace it yet. I just got paid today so I will order one once I leave work.
thanks for your help
matt
matt
