IDLE Questions......
PlatinumTracks
90
CA
:1zhelp:
I know this is a very noob question but please bare with me.....
what would be a good idle and how do i adjust it....
carfanatic89
Texas
yes you can adjust the idle speed, well ok on mine I can 1987 with the 7mge. There is screw you can turn with a flat head its to the top left of the TPS. It looks like a open hole but if you look inside you can see a slot for a flat head screw driver. Turn it to idle up or down, But it doesnt adjust RPMs much. Mabye 500 to 600 RPMs. I can get pics tomorrow when its light outside.
AJ'S 88NA
2,419
Florida
Not suppose to adjust the idle with that screw. It is controled by the ISC and ECU, if it's not idling right then there is something else that needs attention.
BlackDynamite
KTHXBIA
Feb 24, 2007
714
Oregon
when i advanced my timing to 14-15 Degree's, it bumped the rpm to 950. I actually like it that way vs the 600ish. But if you don't know what you're doing, do not fiddle with timing just yet ;]
