Compression checked.
Cylinder 1 - 120psi
2 - 140
3 - 135
4 - 135
5 - 140
6 - 140
Looks like #1 cylinder is too low. Heck, they're all low according to TSRM. I went to my friends shop to check my timing. His timing gun was broke. When I jumped E1 and Te1 codes 24, 31, & 34 flashed. All pointing to the AFM for the most part. It is plugged in, but the map ecu wire harness is also jumped into the main harness. Map ecu is disconnected though. Not sure if that's causing a short or not. I pulled the main fuse to reset codes, but the same one come up. Not that all that matters now cause I'm on a hurt motor. Oh well.
Cylinder 1 - 120psi
2 - 140
3 - 135
4 - 135
5 - 140
6 - 140
