Identify these 2 plugs on my 1JZ please
OneJArpus
2,798
LOL, i did the same thing. It is the cam position sensor. Dr. Tweak sells them brand new i just got mine in a few days ago.
http://www.phoenixtuning.com/zensto...e=product_info&cPath=867_868&products_id=2981
Don't forget the terminals and seals.
OneJArpus
2,798
honestabe;1451184 said:
Matt, IDK. I try and avoid wiring if at all possible unless it's simple soldering. Well there's 1 connector ID'd, what about the other?
Can I get these parts from Toyota since they are from motors sold in the US?
see post #3?, its not hard and its simple wiring. The other brown and white wires looks like another cam sensor unless im missing something
honestabe
Happy as hell :D
Jan 15, 2006
3,713
Mount Vernon, WA, USA
I just have issues reading wiring diagrams. I only ask if I can get them from the dealership since I can get them local. If the other set of wires is another cam sensor then that'll make me very happy. Now I just need to figure out which of my connectors is for my injectors.
OneJArpus
2,798
honestabe;1451240 said:
do they come with pig tails so I can solder to them? How does it all go together?
it comes bare plug, two terminals, and two seals. You have to pin the connector with wires then solder together.
You could possibley ask Dr Tweak to do that for you. I'm just doing it myself. Not too hard to put wire in the terminal then crimp a lil solder for extra insurance the seal put in connector then solder the two.
cost me 24 bux just for the connector terminals and seals. I already have a spool of wire n everything else so its not too bad.
