Got a 94 tt 6spd . The idle has been acting up staying in the 400 -700 range and wants to/does if you let stall and die in 3d 4th 5th (havent tired 6th) at low rpm i.e 1200 to 1900ish. sometimes in the 2000s
I have changed the spark plugs with ngk-bkr7e, gapped at 25
Checked compressions
180 ,175,175,175,175,175
Cleaned tha maf sensor with "maf sensor cleaner"
And still not running right and still running very rich to the tune of 8 mpg or so
Thought of putting the scanner on it just for the hell of it and
Dtc 13 - engine speed (rpm)
sensor above 1000 rpm is what poped up
Havent been able to find much info on the net so far
Any advice would ?
would be very greatfull...
Any advice would ?
