Hey All,
So I did an LED swap on my cluster, climate control, hazard, Fog, defrost, TEMS, and replaced the small bulbs with LED bulbs. I dont remember exaclty how long ago but the (BATTERY, DEAD LIGHT, & E-BRAKE) indicators come on, all together... they will randomly blink on and off during which time the Voltage gauge will jump up close to 18v. I removed most all accessory wires/lighting that I had in the car to make sure nothing else was really affecting it.
The gauges now when turned on are VERY DIM along with the other accessory lights, minus (key ring, window switches). I randomly noticed that the W-G white green wire when touched to a ground, EVERYTHING would come back on and bright like they should... so I spliced a wire just to get them working temporarily. I want to fix the issue permanently..
So.... anybody that can correctly diagnose/help me through fixing the issue gets $10 bucks or more depending on the difficulty...
Things to point out....
1. Yes I checked all fuses
2. The dome interior lights will NOT work by simply pushing them to ON position but WILL come on when the door is opened.
3. Since the issue started i can NOT use the dimmer to adjust the gauges/accessory lighting when the W-G is grounded.
4. I CAN adjust the dimmer with the W-G NOT grounded but at the same time the lights are all VERY DIM. (as explained in the video)
For anybody willing to help me out questions, PM's, and Texts are welcome 541-805-52 zero one.
Thanks
Thanks
