i want a 2 step to work with my maft pro
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
well i was looking at the msd wen site and i know i can run a
msd dis 4 with my stock coil packs then venture to a msd coil packs
but will a msd digltale 6 work with stock cps and such as in make it work with out re inventing the wheel to much
and some one told me you can get the digltale 6 to control coil on plug
(cop)
i really just want a 2 step and i guess better spark
and to control how much dawell i can put in as well (aka on how long the spare hangs around for when it fire's)
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
NashMan said:
Well I was looking at the MSD site and I know I can run a
MSD dis 4 with my stock coil packs then venture to MSD coil packs.
But will a MSD digital 6 work with stock cps and such, as in make it work with out re inventing the wheel to much?
Also, someone told me you can get the digital 6 to control a coil on plug
(cop) setup.
I really just want a 2 step and I guess better spark, and to control how much dwell I can put in as well (aka on how long the spark hangs around for when it is fired)
Translated :)
bigaaron
4,692
Pomona, CA
www.driftmotion.com
By the time you have bought a maft pro, and an msd ignition with all the adaptors, you already spent enough money to get a standalone ecu that already has a 2 step built in. You would also have a lot less complicated setup with about 1/4 of the wiring and connections. Just food for thought....
NashMan
Aug 5, 2005
4,940
17
Victoria BC
yes that si thoiught but if you can get the box for drit then it is ok
but the box that i can get digltale 6 but i am not fully shure it will work wiht out alot of hasle liek remaken triger for the cps ect
thats all i want ot know
cause teh dis 4 should work with out much hassle mabey
NashMan
Aug 5, 2005
4,940
17
Victoria BC
well there goes that idea i don't wana make trigger wheel
this is what i thought you can not mkae the d6 work they way i want
cuel
1,536
Baytown, Texas
MSD sells the trigger wheels, sensors, everything. You just have to fit it is all. Not a big deal, really. I'm sure you could wire the CPS to work as well, just I've never tried to do it. Seems installing the crank sensor and trigger wheel would be easier.
NashMan
Aug 5, 2005
4,940
17
Victoria BC
hummmm
but i don't know if choudl fully get rid of the cps the computer needs it
plus there is only 2 bolts on the damperner witch is not eghough for me to bolt on a trigger but thanks for the replie dude
i think pretty much have to get the dis 4 to bad they don't make dis 6
