i think!!!
johnathan1
Supra =
Aug 19, 2005
5,056
3-wire MAP sensors are basically the same...You can use a GM 3-bar MAP sensor with an HKS-FCON. Probably would work fine on a 1J too...lol. And yea, it seems like the 1J ECU's leaky capacitor issues are rather common, might want to check that out.
AZN MK3
341
Now in the U.S.
itr.00-1282 said:
i've used a 3sgte map on my 1j, worked perfect. either your map is bad, or the wiring to the map is bad. or.....your ecu.
it's not hard to check, it's just 3 wires from the ecu to the map basically.
check as in... check the wires out with a multimeter???
AZN MK3
341
Now in the U.S.
how can you check to see if you have a leaking cap??? i've looked at my ecu and i've found none.. unless its easily mistaken.
Ken
350
Houston, TX
yeah, get the 1jz efi wiring diagram and check continuity of the 3 map sensor wires using your multimeter set to ohms.
AZN MK3
341
Now in the U.S.
ok i checkd and im getting .03 on all three wires... and a long annoying beep... so i know continuity is good and so are the wires.... so im guessing its the map like joe said...
