I think my Twins are dieing!??!?!??
bluemkiii
redmkiii's little brother
Jul 25, 2007
729
phoenix, AZ
87soup;1069984 said:
whats that???
Those are the fitting sizes you need for your oil lines. You should really search these these forums, Im sure this has been covered plenty of times...
Slow_Sc3
I beat bikes dude
Apr 2, 2005
401
Maryland
yep
also your going to need a fitting that is 12mm x 1.25 to 4an for the oil feed off the side of the block.
i normally just cut the bottom of the oil drain tube and leave about an inch of pipe because the 12an ss hose will slide over that pipe and then all you need to do is use two worm clamps ( one isnt enough incase it fails) and you oil line setup is complete.
dont use 10an drain with a 4an feed you will blow the oil seel's out of the turbo and it will smoke badly and in my opinion a 3an line for the feed just isnt enough oil for the turbo.
