i need YOUR innovation!!
knucklebuster
29
St. Louis
My last post was about the fuel line bracket and how it needs to be replaced. Well, i called Toyota and few other places and NOONE makes or produces that part anymore. Its just a fuel line bracket with a banjo fitting on each side. That fitting is stripped out beyond repair. Now i have to find someway to bypass that bracket. Does anyone have any ideas of things to do, like cut the hard lines before the banjo fittings and connect the two pipes somehow? Anything?
whitemike
1,164
Winter Park, Florida, United States
You could replace the entire thing from the rail, or just like you side cut the hardlines, maybe flare them a little, and put a hose on with clamps..
OR, just ask someone who's parting their supra for that piece. There's enough junk 7M's out there where someone's got to have it. I used to have an extra but I think I threw it out. I'll check though.
-Mike
MDCmotorsports
Indy 500
www.MDCmotorsports.com
In the past I just cut the bottom steel hard line, flared the line, then made an AN fitting style, braided steel hose to go to the fuel rail. DO NOT USE RUBBER HOSE AND HOSE CLAMPS for the replacement of this part.
