I need help with wiring sensors.
Mr Bojangles
268
Madison, WI
If you're running aem I would look up the pinouts for the ecu and figure out where in the clip the wires need to go and run new wire from the sensor to the Ecu and loom them up and not fuck around with splicing into the existing harness.
There is no factory boost Solinoid. So you have to run new wires. There are unused spots both on the aem and stock harness connectors. You need to check with the aem to see what you can use for what.
Also what engine?
