I need an idiots guide to wiring an engine.. ive dug myself into a deep hole :(
WeDgE
Buh-bye 7M...
Jan 2, 2006
495
Alberta
I've removed countless remote starters from vehicles that have been installed for 10+ years and haven't seen ANY with a broken solder joint...and some of them were pretty horrific installs. I see no problem with soldering on a wiring harness if you use the proper amount of heat and solder.
Keros
Canadian Bacon
Mar 16, 2007
825
Calgary
mattsplat72;1575468 said:
Total thread derail
I disagree, I think the discussion above is exactly what alot of people need to read before undertaking a serious wiring conundrum.
I couldn't figure out if EvilEmpire and Dirgle were arguing or agreeing, but I guess those military types are like that ;)
87supraguy
808
Tucson, az
i could be wrong but what i think what he was looking for was a step by step process of how to wire the engine harness.... i agree w/ mattsplat72, yes a little off topic but i also agree w/Keros, we definetly need to know how to properly connect wires together to even do a harness...
JP85MX73
79
NY
This would help also lol
jmcboost
Missouri
Same here, soldering used the right way (no cold joints) will last a long time. No problems here. But as far as wiring a harness goes, it's just about reading up on what wires you need to use and getting them to the right spot. Then make a good solid connection and you should be good to go. Good luck!!
