1 tooth on a 7M is like 14 degrees and probably similar on a JZ. Definitely will make it run like shit.
just a walbro 255 in the tank. still all stock injectors and regulatorIBoughtASupra;1789322 said:Pull the plugs and see how they look, maybe they are fouled?
Also, any upgrades to your fuel system?
i also put new plugs in it525gte;1789362 said:just a walbro 255 in the tank. still all stock injectors and regulator
te72;1789373 said:I've also seen people post that running copper plugs can return a less than ideal idle, but they do run great under boost. Every once in a while mine will stumble a bit or idle a bit odd, but it always runs great when it counts, so I never really looked into it. Also, make sure your gap is the same on your plugs. ~.028 is a good starting point.
whoops yup just notice ,, i ment closed , brain going to fast for fingures thiermecevans;1789457 said:Think you mean Closed loop = uses feedback from O2 sensor.
you were right. i swapped the cams out this last week for the stock ones. and now the car idles perfect 14.5 to 15. iac still is not working. but after thinking about it longer, decided that i have the iac possibbly wired wrong. have it turned on via a relay and keyed power. and the relay should be getiting turned on for the iac via the ecu. im thinking that the ecu sends a singnal back to the iac after the car turns off and resets the piston inside as a reference point. . and becuse its going off with keyed power. its not getting that signal. . just a idea i am going to exploreT701jz;1788165 said:Put back the stock cams and you're good to go.
water temp is new,, that was the 1st thing i replaced. have not cked air temp i will just replace it i think their cheap. and the tps is adjusted. i have gotten pretty good at justing it with a volt meterbut i will take a look at the butterfly. thanksT701jz;1796144 said:I would double check also the water temp sensor and the air temp sensor are in good working order. I would remove both of them for inspection. My water temp was corroded badly inside. I would make sure also that you set the TPS correct and the throttle valve is completely close when you reset it. Make sure you top your water level to the max for consistent reading to the water temp sensor.
