Hi to everyone in the Supra family,
Not for sure when the best time is to start a build thread not knowing how long its going to take. :icon_bigg
But why not start now! Heres my story...
I found this 1992 black MKiii targa 5 speed turbo for sale with dark shadow gray leather interior. I was wanting a project car to start on but wasn't for sure what to go with. In the past I had drove Mustangs, Camaros, TransAm's and one 87 Turbo Supra. All I could think about was how that old Supra put a big smile on my face the first time I took it out for a test drive. All I remember was how it pulled really hard when the boost gauge started to climb and I was so amazed! I had never rode in a turbo car before and it just made me laugh because it was so fun! So I made up my mind to buy this 92 Supra but it wasn't easy. This Supra was for sale on e-bay in Baltimore Maryland and I lived in Kansas. I had to bid on this car to the very end and won! Then I told the wife I needed a one way ticket to Baltimore Maryland. She said "your crazy if your going to buy a one way ticket and take 2 planes all the way to Baltimore Maryland and drive back home!!!" I said yea... maybe.
GOALS: Daily driver 600hp at the wheels with E-85. You guys can be the judge of that after reading the parts list and hopefully guide me in the right direction. I could use any good advice you all are willing to share to help me reach that goal. Thx.
I have plenty of pics to show but will take a bit to find and organize them. Ill put down a list of parts that I have and if I missed some then I'll go back and edit/add the parts to the list. I already have pics in my profile if you need to see them right away but Ill get started.
I pulled out the 7MGTE and bought the 1JZGTE with 5 speed trans from Nagano Japanese delivered to my front door.
Parts list no specific order:
HyperTune Billet Intake Manifold kit with 90mm throttle body & fuel rail. (Suprastore)
Dynamics ID 1000's injectors (Suprastore)
CP piston set .20 over (Driftmotion)
ACL rod bearings (Titan Motorsports)
Clevite main bearings (Driftmotion)
Stock metal head gasket (Driftmotion)
ARP bolts for the 1J and ARP wheel studs front/back (Driftmotion)
Precision Turbo 6262 .84 A/R T4 divided 6262 CEA Polished Billet waterless DBB SP cover with QSV (Sound Performance)
QSV Super HD design (Sound Performance)
1JZ head hot tanked, decked, port/polish lash setting, shimless buckets, 3 angle valve job & polished cam covers (Suprastore)
BC valve springs (BC)
Modified oil pump
Titan cams 264's with Titan cam gears (Titan)
Exhaust Quick Silver Manifold Black Techline Ceramic coating T4 (Suprastore)
Pro-Efi 128 with E-85 kit and color can display (Sound Performance)
Engine rebuild kit (Driftmotion)
Titan Billet Timing Belt Tensioner (Suprastore)
ATI Super Damper (Summit Racing)
R154 5 Speed by Marlin Crawler full HD package including HD thrust washer, bearing retainer plate & billet 1-2 shift fork
Short throw shifter V2 group buy (Nashman) http://www.youtube.com/watch?v=Q_frLIPhk6k
1JZ/2JZ Engine brackets 89-92 (Driftmotion)
Poly Subframe Bushings group buy (Ronniek)
Poly Trans Mount R154 (Driftmotion)
Energy Suspension Bushings black lower control arms
Beech upper control arms and all adjustable suspension front and back
Whiteline adjustable sway bars front/rear
BC Coilovers BR type front/rear
Arizona Performance BBK front/rear
Tweak'd Performance harness
NGK BKR8EIX plugs
Fuel Labs 6 micron filter, Beech Fuel Hanger, 2 AEM 320 lph pumps (Driftmotion)
For fun... devil horns Toyota badge (Tekdeus)
Clear corners front blinkers with LEDs (THMotorsports)
OS Giken rear differential TY021
OS Giken gear oil 80W-250
Modified oil pump
NGK BKR8EIX plugs
