IJ.;1980868 said:It's not quite that simple, I replicated the stock signal with my MoTeC and it's variable voltage not on/off.
Voltage from memoryDirgle;1980871 said:Is it variable voltage or PWM?
This was with the LSx, my car was non PPS being an 86.5.jdmfreak;1980872 said:Maybe I wasn't very clear but that's what I meant by "reduces the voltage as speed increases"
And if what I have read is correct it should be fully stiff by 80mph... Did you use the MoTeC to replicate the signal to change the parameters? (have the steering stiffen faster) or for some other reason??
