1jzsupbra said:Why are hybrid twins always being knocked? Who has dyno sheets to prove that they arent that good? The price may be high, but it's a bolt on affair. That may be worth it to someone. Lets see some dyno sheets and hear from someone has them! I will trust their opinion over someone thinks/heard that they suck.
drewgo said:Manifold 350
DP 150
Tial 38mm WG 200
Master Power 62-1 580
fittings, Oil Lines turbo Vband Clamp ~ $100
Providing you have 1jzgte this kit will need minor fabrication to connect your exhaust to the Dp and IC piping to the turbo. Also providing you have a BOV.
OneJSupra said:so for around $1500 you can get this system installed complete with everything but the tuning cost. Do you sell all these?
Casue there are better options out there. In the end the CT12s have small shafts and will wear out quicker then a proper turbo.1jzsupbra said:Why are hybrid twins always being knocked? Who has dyno sheets to prove that they arent that good? The price may be high, but it's a bolt on affair. That may be worth it to someone. Lets see some dyno sheets and hear from someone has them! I will trust their opinion over someone thinks/heard that they suck.
tissimo said:Casue there are better options out there. In the end the CT12s have small shafts and will wear out quicker then a proper turbo.
I really think the HKS kit is the best. Looks stock, but has twin T2 manifolds (i'm sure better flowing then stock) and gt28 turbos.. They're fairly hard to find, but usually ~ 1000-1500 i've seen. Easily 400 whp setup but looks bone stock.. plus you can brag you got hks yo!
OneJSupra said:if you can this get kit will you need to upgrade your fuel system or the stock can handle 400 whp.
