hx35 on 7mgte
IndigoMKII
2,181
Madison, Virginia
Couple more photos of parts that I've collected.
Driftmotion t4 turbo manifold and hks 50mm wastegate with -10 an oil drain lines and fittings
t4 turbo blanket with graphite colored exhaust wrap and the hx35 7 blade with the bracket removed from the compressor housing and the turbine housing shaved a little bit for less weight
New arp hardware, ARP head studs and rod bolts.
Waiting for a little bit more funds to finish ordering all the bits and pieces to finish this setup. I'll probably also order a new clutch next month, looking for something to hold anywhere from 450-500 ftlbs of torque.
IndigoMKII
2,181
Madison, Virginia
How do you like your 67mm kit? I'm thinking of selling the hx35 for something a little bit bigger.
Which act extreme clutch? They sell all different kinds.
claytonwes_2
28
sequim washington
I Have the hx35 on my 1jz and its an awesome turbo for the street. I cant imagine the spool with the extra displacement of the 7m. I have an act extreme pressure plate with the street disc and it is pretty streetable.
Sent from my LG-C900 using Board Express
IndigoMKII
2,181
Madison, Virginia
What PSI are you running and when do you see it?
8,898
IndigoMKII;1912660 said:
the t4 to t3 adapter I'll be making.
Not that money grows on trees or anything, but Cartech will still make you a manifold and they will make it T3 or T4. I talked to them recently. They still do intercoolers, but switched it from 8 to 6 inch core. That was also a part of the talk. I think it is better to have a dedicated manifold than to use adapters.
IndigoMKII
2,181
Madison, Virginia
thanks for that info. I might be going 67mm t4. the hx35 might be for sale soon as this project is on the fence.
