humm i wonder 93+ rear brake's
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
well since i had brake on my mind i had thought and think i have herd befor but i don't know if it's ture
well i vagly remmber some talking about this
take mk4 na rear caplers and swaping them on the mk3
cause the rear piston was bigger then the reg mk3
this is what i have bean thinking of but i don't know if it's worth the time
think ls400, ls300 has teh same rear brake as the na mk4 supra
i think there the same and we have one at the local yard mabey i can compair the the 2 i migth find an answer
NashMan
Aug 5, 2005
4,940
17
Victoria BC
oh it will fit cause mk4 rear's are swapable on mk4 supra's
and mk4 can be easly swaped on mk3's
both are priced the same as in na rear to mk3 rears
shaeff
Kurt is FTMFW x2!!!!
10
Around
^Yeah, I know that. :) I have one of Jake's kits to put them on. ;)
NashMan
Aug 5, 2005
4,940
17
Victoria BC
you don't really need any thing speail to install tehm not kit is needed dr jonez did this long ago
so i guess know one knows if the piston is bigger eh
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
To "install" them, sure, but I would rather not be removing material from a cast component to get the brakes to work...a centred rotor is nice to have as well.
If i recall correctly, the mk3 rears are ventilated, are they not?
Doward;1189612 said:
The size of our rears don't bother me - it's the lack of ventilation that does.
Ian, are the MKIV TT rears ventilated?
324mm diameter from memory John, rgr on vents (they all are Mk3's included)
Can't remember thickness off the top of my head either 16mm or 18mm I think.
I'm using DBA4000's front and rear.
tsuper92
supra addict
Apr 7, 2005
1,376
mass
you can press a mkIV hub into the mkIII carrier's,then it will be hub centric.the rotor will also be centered in the middle of the pads
