Huge oil leak
92TealSupra
Supramania's Parts Man
Sep 2, 2008
1,584
Great Lakes State
1wickedA70;1563255 said:
same thing happened to me only mine was only dripping a bit....it all happen after i installed the 2jz oil pump and put on the 1jz front main seal. when i took everything apart it seemed as if the lower part of the seal was out not evenly pushed in, thats my guess. does it matter that i have a 1jz front main seal with a 2jz oil pump? and should i buy a new seal?, the one i installed is brand new and doesnt look pinched at all.
---------- Post added at 10:36 PM ---------- Previous post was at 10:35 PM ----------
what do you mean the spring somehow escaped?
I am not sure if it does matter, I hope to see pics though. Like IJ. under pressure this would be leaking good. I think the crank seal is leaking from the sound of it.
