Stroked 7MGTE = Tourqe
Funny thing is on the same turbo/fuel and tuning, the engine stock made about the same rwhp at the same psi level. BUT stroked, it's making around 100ftlbs more rwtq.... So it feels faster, and it is very nice to drive around town.
Stock IIRC is 91mm stroke, with my mods, it's 97.5. The bore is just under 84mm, so pretty much stock with enough to remove any scratches when you rebuild/modify it. (Maintaining as much integrity/structure of the block as possible.)
You could go to a 85.5mm bore, with the 97.5mm stroke, and get something close to 3.4L of displacement, sure to make even more tourqe, and possibly more HP too but at the risk of breaking the block when you turn up the boost.
My 3.24L engine is fine as it stands however. (Would like quiet pistons at cold start, but can live with the "diesel" truck sound till it warms up...) Especially since it pulls like a diesel truck all the time now too. (With the top end of a typical I6, so a nice combo indeed.)
My "small" T04 based bolt on turbo is going to be changed to a medium sized compressor wheel, ebay manifold, and twin scroll hot side. (So, going to keep the BB CHRA with the stage V exducer, add a .84 divided V band housing, and go with either a 62 or similar compressor and larger compressor housing with the 4" inlet and 2.5" outlet for more flow, and hopefully not much more lag than what I have now.) Getting rid of the damn internal wastegate will be worth it all even if I just keep stick with the current 60-1 compressor and small cover I have. (3" inlet, 2" outlet, basicly same size as the CT26 cover.)
Right now, this 60-1 acts like the stock CT over 5000rpm... where on the stock engine, it pulled to redline, it's becoming restricted now on top. so I need to open it up some.
