hey guys do you know about how much hp a mostly stock manual 7mgte would make on 12 lbs of boost? numbers dont gotta be exact cuz i know there are a million mods that affect the numbers, but about how much- wheel or crank hp? thanks.
Wow...nice. I'm in for a treat when I do my 7M-GTE swap then. I'm used to the 1.6 4A-GE and the 2.0 3S-GTE...it will be nice to feel some real power.CzA;1202737 said:i put down 274HP to the wheel so around 328(approx) from the crank,
Mods, 12.4 psi. 3 inch elbow back(no cat), intake.
MasonF;1202929 said:Wow...nice. I'm in for a treat when I do my 7M-GTE swap then. I'm used to the 1.6 4A-GE and the 2.0 3S-GTE...it will be nice to feel some real power.![]()
isnms - 268.40whp/299.13wtq - k&n fipk, cartech ic series 2, defcon ic hardpipes, ct26 50trim, BIC 3"dp, high flow cat, 3" cat back, cometic, spec stage2, hks s-afr
17.
15. xarewhyayen - 272.94whp/324.75wtq - mhg/arp studs, 3" elbow w/ HKS replica 3" dp, test pipe, Tanabe Hyper Medallion Cat Back, Greddy Profec E01, Upper hardpipe w/ Greddy Type RS, K&N w/ LIPP adapter. Spec stage 3
