HP and TQ guesstimates with this setup...
InFrnt0fU
Lurking Supra Socialite
3in DDP with full catback, 57 trim upgraded ct26, 550cc, lexus afm, spearco FMIC, hhks bov, KN FIPK kit, MHG with 8.6-1 ratio stock internals. What psi is safe/reliable for the 57 trim upgraded ct26 and factor that in. This is probably gonna be my setup come the end of the year. Thx
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
Valve shims within the right clearance.
Tolerances between cam caps and cams within spec.
Rod and main bearings within spec.
Compression and leakdown both good.
TPS within spec.
Correctly working KS.
AFM resistance within spec.
Cooling system fully refreshed with new parts.
New oil pump.
Oil pump drive shaft within spec.
Egr system cleaned out.
Basically, making sure you have a fully refreshed engine before you dive into modding your car like that. If you don't, it will break, period.
InFrnt0fU
TPS within spec.
New oil pump.
You couldn't be more helpful, thanks a lot man.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,240
Atlanta
As for your original question, I would expect you to make about 300-330HP on low boost(~10psi) with that setup, provided the engine is fresh, as stated above.
