I noticed the same fault. It should be the yellow wire from IJ1. I figured out most of the wiring myself because most swap reports are still containing some mistakes/incomplete, and I want everything to work as it should (didn't test it yet though)
But yesterday I found this site
http://1jz-gte.webs.com/soarerharnessintoma71.htm (I believe that is your site 92TealSupra?) That is the most complete swap report. Every wire/colour matches :icon_bigg
There's only 1 wire that I'm not sure of where to connect. It's the blue wire from EB1, it says connect to old AC connector. Do I connect that one to the blue wire from C1 (That wire goes to the A/C temp switch)? Or is there another blue AC connector wire?
