Ok so I had this problem with my old precision last year, and now I've run into it again.
How do you guys tighten the top right bolt on the turbo to the manifold? I have a xs power manifold.
To me it seems as if I need to pull the exhaust housing off, bolt it down, then put the rest back on.
The bolt won't fit in the top right bolt hole on the turbo, because the housing won't allow enough room for the bolt to straighten out to go through the hold. The way Im trying is I have a threaded rod, acting like a stud, in the manifold. But I can't fit a wrench between the turbine housing and compressor housing to tighten then nut.
I'm just wondering if you guys have run into this and what you did to tighten that side down.
(idk if it's just precision turbos, that's just all Ive run)
Thanks
Thanks
