HOW TO : Paint gauge cluster, kindof neat..
Status
Not open for further replies.
Bootymeat
51
Bev Hills 90210
So I got bored searching on SM.com last night, and decided to paint something. I grabbed my Plastic Tamiya Chrome Silver "X-11" and decided to paint the gauges. It turned out really well Actually. Plus I got to clean up a bunch of stuff.
Here's how to do it.
First you have to remove the gauge cluster from the car. It's simple, you will need a 4 way screwdriver.
1. You'll need to remove the shifter surround, in automatic transmissions you'll need to put it in "L" to get it out. Or 4th gear in a 5 speed. Just don't start it "Some neutral switches don't work!"
2. Remove the Screw on the drivers side by the sifter
3. Remove the ash tray, pull it out, and remove the 2 screws (They will be up top of the ash tray hole), remove this.
4. Pull up by the coinholder or "TEMS" buttons on the shifter surround. It will pop, but it's rivets so you're good.
5. Remove the headlight washer harness (Only the sport packages have this.), the hazard switch harness
6. Set this aside, and start with the Coinholder, Cruise control, ect. You will have only 1 screw on the bottom, feel around and you'll find it.
7. Pop it out, remove the harnesses from the switches.
8. You'll see a screw directly in front of what you removed, it's holding a black piece that surrounds the top of the gauge cluster, remove that, and all the ones along it. Remove this.
9. Remove all the Screws backed by white plactic on the gauge cluster, pull it directly towards you to remove the speedo cable from cluster.
10. Remove all the clips in the back, and angle it out to get it past the steering wheel. And bring it inside the garage or house.
Now you'll need to remove the clear guard. This is pretty simple, be careful, if it doesn't want to remove you're missing something and don't pull hard.
1. It's a total of 8 screws and the odometer reset.
There are 6 total screws on the top, pretty straight forward. Then the 2 by each vent holders. Next the odometer reset, simply turn this counter clockwise and the tip will come off, allowing it to remove completely. Next you'll need to (Just slightly) pull the back of the clock wires. Now you have to use a small flathead screwdriver, to remove the vent clips. 6 total. It will remove the full clear plastic piece.
After this, set it aside on something soft.
Now you have to remove the black piece, this is also easy but be careful..
Remove the vents by fliping it over on it's back and removing there will be a total of 6 screws. Finish by removing the screws holding the boost gauge wires and the security wires in place (2 security, and 3 boost)
After this, paint, let dry, paint and see how it looks. Before you put it all back together, clean the vents with a couple q-tips and use glass cleaner to clean the inside and outside part of the clear overlay. You can paint it any color you want, and switch things up. You'll have to take the same steps to do the chrome gauge bezel you can buy from vendors.
Here's the outcome!!
RazoE
Boobs/Boost, my favorite
Jun 13, 2006
4,946
Los Angeles
www.cafepress.com
I have to see pics of it installed in order to pass judgement..
HIDPLANET
89 1JZGTE
To each their own. I used to do simple things like this back when I was 16-19 but I prefer a stock looking cluster for the most part which is why I also dont get indiglo gauges or things like this.
Ok, i'll stop my old man rant. But im sure it doesnt look bad when done right, its just not for me. Although id love to see finished results as much as anyone else here.
Dylan JZ
一番 King
Oct 18, 2007
2,220
湾岸せん
I was thinking of doing mine is a shade of silver or gunmetal as well, but I decided instead to paint it gloss black.. still an improvement over stock.
Sawbladz
1,727
Oshawa, ON, CA
Seems like a lot of work to give your dash the rattle can look. I have a feeling mods like this are regretted by their owners. Especially if they try and sell the car.
Athena
Rawr
Jun 22, 2009
154
Raleigh, NC
I think it looks good. an installed pic would help if I would ever want to do it to mine. Leaning on the not side though. Just not the look I'm going for.
Nice though.
Athena
Rawr
Jun 22, 2009
154
Raleigh, NC
Nice though.
RazoE
Jun 13, 2006
4,946
Los Angeles
www.cafepress.com
I can take the cluster out and have it apart within about 5 minutes, so it is an easy mod in my eyes, but you can always paint it back, right..?
not sure how the stock bezel holds paint (since the material is kind of rough)
Status
