I recently installed bic ddp. Since then my car has been spiking to abot 18 psi and then backfiring. (stuttering) It's almost like fuel cut, but different. Don't really know how to explain it. Before the ddp, I was running aroung 9.00 with my best time a 8.78 in an 1/8. Now I can't floor it cause my car spools too much and sputters. I have a manual boost controller, but my car still spikes to 18 psi. Would a electronic boost controller stop this? My wastegate is suppose to be set at 14 lbs., but apparently not.
Can I have the divorced pipe welded and extended to go back into the exhaust? Would this make it run more like it did before I installed it? I was also thinking about adding a muffler to divorced pipe. Maybe that will help. I don't know, that's why I'm posting on here. I really need some help, cause I'm tired of not being able to push the petal to the metal when racing. I raced tonight earlier and I did run a 9.13 but that was my best time and that used to be a bad run for me. Hope someone can offer some help............lol
