So, wait... If I just buy a small spring i'll make more power and spool quicker? So then, whos going to tell me where to buy this spring and what size it needs to be? Oh, and how to install it... KthanxBye!
7Matt-GE;1767919 said:i would go the port and polishing...you push more air through the turbo that way. i guarantee you will see a lot of results from that.
okay thank you! just got a rotary grinder been itching to try it out lolT701jz;1767954 said:Exhaust Header and eliminate any back pressure down the line.
92ma71;1768269 said:IMO, using your small rotary grinder eating up pieces of grind tools trying to port out your header real quick is definately NOT worth pulling all that stuff apart, spending hours doing it, and putting all stock crap back together and nothing is flow matched etc. For what kind of gain? Ive heard of losses (nothing documented that I know of for proof just what I heard) by doing to much grinding etc. Unless this stuff is already pulled apart and you have done extensive research on porting your header, I would not waste my time.
What are your mods so far?
I needed all the help I could get, as my understanding of the engine's system is tiny at best. I relied upon the engine builder, one who builds performance and racing engines for the likes of Horsepower Freaks. Also, there is a small shop down the street called RSI, that was used to test the flow of the head and exhaust manifold.rodama5anthony;1768346 said:interesting. thanks for the info van, anymore advice you have to offer?
